hxcfe command line utility error
mikeyp
Post by mikeyp »
I'm using a script to generate my floppy images and inject the files into the HFE images. I keep getting the error in the output below but all seems to work ok. Just wondered if you were aware of it or if I'm doing something wrong.
The blank HFE file was created in March using the GUI. It is copied, renamed and then the files injected.
Thanks again!
HxCFloppyEmulator_soft\hxcfe.exe -finput:FLOPPIES\DSKA0828.HFE -putfile:ROMS\FLOPPYROMS\VALIS4U.SWC
HxC Floppy Emulator : Floppy image file converter
Copyright (C) 2006-2016 Jean-Francois DEL NERO
under certain conditions;
libhxcfe version : 2.8.9.4
Input file : FLOPPIES\DSKA0828.HFE
File Image: FLOPPIES\DSKA0828.HFE
Checking FLOPPIES\DSKA0828.HFE
File loader found : HXC_HFE (SD Card HxCFE HFE file Loader)
Loading FLOPPIES\DSKA0828.HFE
file loader found!
File type : HXC_HFE - SD Card HxCFE HFE file Loader
Floppy interface mode : IBMPC_HD_FLOPPYMODE - PC Interface (1.44MB/HD Disk)
Number of Track : 80
Number of Side : 2
hxcfe_readSectorData : ERROR -> Sector not found ! track 0, side 1, sector 19,Sector size:512,Type:0
hxcfe_readSectorData : ERROR -> Sector not found ! track 0, side 0, sector 19,Sector size:512,Type:0
Put ROMS\FLOPPYROMS\VALIS4U.SWC
Files size : 1049088 Bytes
Create /VALIS4U.SWC
Write HFE file FLOPPIES\DSKA0828.HFE for the standalone emulator.
Floppy interface mode IBMPC_HD_FLOPPYMODE (PC Interface (1.44MB/HD Disk))
80 tracks written to the file
Stopping HxCFloppyEmulator...
Re: hxcfe command line utility error
This is normal, the library try to count how many sectors there is per track.
Any i agree that this "error" message should muted.
