Akai s950 floppies to SD
sleestack808
What is the best way to transfer s950 floppies to an SD card? Thanks
Re: Akai s950 floppies to SD
You can use the HxC software if you have an PC with an internal floppy drive.sleestack808 wrote:What is the best way to transfer s950 floppies to an SD card? Thanks
sleestack808
and presumably an SD card input? An internal floppy PC with sd card would be the ideal? I guess it would be easier to buy an external sd card reader to hook up to an old windows machine with a floppy drive. Im so confused
