Does it work on a Roland XP-80 synthesizer?
johnmx
Post by johnmx »
Hi you all,
First of all let me congratulate the owner for this great project.
My Roland XP-80 floppy disk driver is not working very well. Do you know if this circuit (the PIC stand alone version) is compatible with the synthesizer?
I know that the floppy data system is the same used by IBM PCs. So I can copy files and even format the floppy in a Microsoft Windows PC to be used in the XP-80. Does it mean that this circuit is compatible (since it works on a PC)?
Best regards,
johnmx
Re: Does it work on a Roland XP-80 synthesizer?
johnmx wrote:Hi you all,
Best regards,
johnmx
This "should" work with the floppy emulator, since the Roland XP-80 used ms-dos type floppy disk.
However, nobody has tested it on this synth.
dvieiraj
Post by dvieiraj »
Best regards,
johnmx
I also have a roland keyboard (model alpha-1) and would like to know if this device will work with my keyboard. In this model the green light is always "on" from floppy.
I use floppy to read new styles (.stl) and midi (.mid) files.
