LNW80 format issues
evad
LNW80 format issues
Post by evad »
evad wrote:
Jeff wrote: Exactly. During the write process, the virtual disk rotation is paused. So if the host machine have a too strict write/disk rotation timeout value, this maybe a problem. That's why a fast SD is recommended in these particular cases.
During any read process, you shouldn't see these kind of "throttles". Anyway, try to use the very last firmware version :
New Thread
Jeff,
Thanks for the response.
Already running v1.8.2.40 as I just received the unit 2 weeks ago. ( Version shown on boot flashes by very fast )
I am using Sandisk 8gb. Ultra SDHC Class 10. They are 40MB/s instead of 30MB/s as shown on the site http://lotharek.pl as tested cards.
I have ordered SanDisk Extreme SDHC UHS-I/U3 16GB Memory rated at 90MB/s read and 60MB/s write.
Hopefully these will work :)
The latest version is the V1.8.6.15a
Jeff,
I have installed the latest Firmware and have received the Sandsk Extreme 90MB/s read 40MS/s write SD cards. ( Yes they sent me different than advertised - they were to be 60MS/s write)
Still having format problems with the LNW80. For Newdos80v2.0 I have patched SYS6 to ignore "Motor Slow" error as we have discussed in another thread. The format fails on Double density.
For LDOS5.3.1 the format attempt also fails on Double Density.
In both cases above I can successfully format and verify a DSDD diskette in a real floppy drive.
The only difference I can find between the LNW80 and TRS-80 model 1 is that the LNDoubler5/8 forces Write precomprehensions for all double density tracks.
Per manual...
" Write precompensation is factory aligned to 200 ns +-25ns and is enabled only for double density operation (all tracks 5.25" and tracks above 43 for 8")."
Any Ideas???
Re: LNW80 format issues
evad wrote:
Jeff,
Per manual...
Any Ideas???
If you want to format and write a SD image with DD Sectors and vice and versa, you need to change some flags into the HFE file.
There is some flags into the HFE file to indicate to the emulator which mode will be used for the first track (Side 0 and Side 1) and all others tracks.
These flags are set automatically by the HxC software when you generate the HFE file. It just check the track type and report it to the HFE header.
Let me know which track density (SD or DD) you want for the first track (Side 0 and side 1) and the other tracks. I will generate some blank HFE.
evad
Post by evad »
evad wrote:
Jeff,
Per manual...
Any Ideas???
Jeff,
I have been made aware of the changes needed for track zero to be opposite density
I would be extremely happy to just be able to format ALL tracks Double Density.
LNDoubler5/8 FD1791 Double Density Single Sided - 40 track, 256 byte sector, 18 Sector per track
NewDos80v2.0 Parms TI=C,TD=E,TC=40,SPT=18,TSR=3,GPL=2,DDSL=17,DDGA=2
Thanks for your help!!
Can you share the HFE file giving you the error ?
evad
Post by evad »
Jeff wrote:Can you share the HFE file giving you the error ?
See attached
An attempt was made to format the HFE file attached.
Dave
EF_40tkssdd18.zip
(22.5 KiB) Downloaded 716 times
The track 0 seems to have some very curious sector layout : Various sector sizes and strange ID. Are you trying to write a copy protected image ?
evad
Post by evad »
Jeff wrote:Thanks
No.. Simply using the DOS format command
Format 1,,,,Y
or
Format 1
evad wrote:
Jeff wrote:Thanks
Format 1,,,,Y
or
Format 1
mhhhh so i can't explain at all what is on this track. It look like the the TRS80 is writing some kind of garbage for some reasons...
I suppose that the same command is working with a normal drive + floppy ?
evad
Post by evad »
evad wrote:
Jeff wrote:Thanks
Format 1,,,,Y
or
Format 1
Yes ..Teac FD 55 floppy drive with no errors SD or DD with a verbatim DSDD disk
Note that I can format a Single Density HFE with no errors...
evad
Post by evad »
What tools do I need to help debug?
evad wrote:Note that I can format a Single Density HFE with no errors...
Quite interesting
evad wrote:What tools do I need to help debug?
I just use the track viewer into the HxC software to check the HFE file.
Try to regenerate a blank MFM image (with 0 sector) and retry a format. Then share again the HFE.
evad
Post by evad »
Ok ... Will do .. Also note the LNDoubler that is used on the LNW80
http://www.vintagecomputer.net/fjkraan/ ... index.html
evad
Post by evad »
Attached is 4 attempts. also note that the HXC is the last one on the cable as is assumed to be terminated.
Also re-formatted diskette in Teac drive to be sure we were still working ok..
EF_40tkssdd18_2.zip
(89.5 KiB) Downloaded 729 times
I see 18 sectors per track on others track. Is it normal ? Did you set the number of sector to 0 to make the blank image ?
