Hi everyone
i'm trying to compile the floppy immulator the pic stand alone version but i always get the following err
any suggestion welcome
thanx
Release build of project `E:\fdd_emu\sources\pic2.mcp' started.
Tue Jan 06 17:44:24 2009
Clean: Deleting intermediary and output files.
Clean: Deleted file "E:\fdd_emu\sources\main.o".
Clean: Deleted file "E:\fdd_emu\sources\lcd.o".
Clean: Deleted file "E:\fdd_emu\sources\utils.o".
Clean: Deleted file "E:\fdd_emu\sources\hardware.o".
Clean: Deleted file "E:\fdd_emu\sources\sdcard_lba.o".
Clean Warning: File "E:\fdd_emu\sources\clearblock.o" doesn't exist.
Clean Warning: File "E:\fdd_emu\sources\fastspi.o" doesn't exist.
Clean Warning: File "E:\fdd_emu\bin\clearblock.lst" doesn't exist.
Clean: Deleted file "E:\fdd_emu\bin\fastspi.lst".
Clean: Done.
Executing: "D:\Microchip\mcc18\bin\mcc18-extended.exe" -p=18F4525 /i"D:\Microchip\mcc18\mpasm" "main.c" -fo="main.o" --extended
Executing: "D:\Microchip\mcc18\bin\mcc18-extended.exe" -p=18F4525 /i"D:\Microchip\mcc18\mpasm" "lcd.c" -fo="lcd.o" --extended
Executing: "D:\Microchip\mcc18\bin\mcc18-extended.exe" -p=18F4525 /i"D:\Microchip\mcc18\mpasm" "utils.c" -fo="utils.o" --extended
Executing: "D:\Microchip\mcc18\bin\mcc18-extended.exe" -p=18F4525 /i"D:\Microchip\mcc18\mpasm" "hardware.c" -fo="hardware.o" --extended
Executing: "D:\Microchip\mcc18\bin\mcc18-extended.exe" -p=18F4525 /i"D:\Microchip\mcc18\mpasm" "sdcard_lba.c" -fo="sdcard_lba.o" --extended
Executing: "D:\Microchip\MPASM Suite\MPASMWIN.exe" /q /p18F4525 "clearblock.asm" /l"E:\fdd_emu\bin\clearblock.lst" /e"clearblock.err" /o"clearblock.o" /y /aINHX8M
Executing: "D:\Microchip\MPASM Suite\MPASMWIN.exe" /q /p18F4525 "fastspi.asm" /l"E:\fdd_emu\bin\fastspi.lst" /e"fastspi.err" /o"fastspi.o" /y /aINHX8M
Error[113] D:\MICROCHIP\MPASM SUITE\P18MACRO.INC 182 : Symbol not previously defined (Ptr)
Executing: "D:\Microchip\MPASM Suite\MPASMWIN.exe" /q /p18F4525 "fast_int_handler.asm" /l"E:\fdd_emu\bin\fast_int_handler.lst" /e"fast_int_handler.err" /o"fast_int_handler.o" /y /aINHX8M
Executing: "D:\Microchip\mcc18\bin\mcc18-extended.exe" -p=18F4525 /i"D:\Microchip\mcc18\mpasm" "fat32\fat.c" -fo="fat.o" --extended
Executing: "D:\Microchip\mcc18\bin\mcc18-extended.exe" -p=18F4525 /i"D:\Microchip\mcc18\mpasm" "fat32\browse.c" -fo="browse.o" --extended
Executing: "D:\Microchip\mcc18\bin\mcc18-extended.exe" -p=18F4525 /i"D:\Microchip\mcc18\mpasm" "hfe_file.c" -fo="hfe_file.o" --extended
Executing: "D:\Microchip\mcc18\bin\mcc18-extended.exe" -p=18F4525 /i"D:\Microchip\mcc18\mpasm" "ihm.c" -fo="ihm.o" --extended
Executing: "D:\Microchip\mcc18\bin\mcc18-extended.exe" -p=18F4525 /i"D:\Microchip\mcc18\mpasm" "floppyemulation.c" -fo="floppyemulation.o" --extended
Executing: "D:\Microchip\mcc18\bin\mcc18-extended.exe" -p=18F4525 /i"D:\Microchip\mcc18\mpasm" "floppypinsstate.c" -fo="floppypinsstate.o" --extended
Executing: "D:\Microchip\mcc18\bin\mcc18-extended.exe" -p=18F4525 /i"D:\Microchip\mcc18\mpasm" "browse.c" -fo="browse.o" --extended
Executing: "D:\Microchip\mcc18\bin\mcc18-extended.exe" -p=18F4525 /i"D:\Microchip\mcc18\mpasm" "fat.c" -fo="fat.o" --extended
Skipping link step. Not all sources built successfully.
Release build of project `E:\fdd_emu\sources\pic2.mcp' failed.
Tue Jan 06 17:44:32 2009
BUILD FAILED
compilation error
Re: compilation error
Hi,gem1144aaa wrote:Hi everyone
thanx
Clean: Done.
BUILD FAILED
this message is due to an error in the P18MACRO.INC assembler macro file (\MCC18\mpasm\P18MACRO.INC), in Stk1PopToReg macro.
To correct this replace the line "movff PLUSW1,Ptr" by "movff PLUSW1,Reg" in Stk1PopToReg macro (line 182)
gem1144aaa
Hi Jeff
I really appreciate your fast help
i did what you said
it compiles ok
but now i got some thing strange when linking
i get this message
MPLINK 4.20, Linker
Copyright (c) 2008 Microchip Technology Inc.
Error - mutliple inclusion of object file 'D:\Microchip\mcc18\temp\browse.o'
Errors : 1
Link step failed.
when i checked for the reason in mplink help it said it is a multiple instance of the browse.o
and when i checked the build line order i found it repeated twice like this and i do not know from where i can correct the problem.
Executing: "D:\Microchip\mcc18\bin\mplink.exe" /l"D:\Microchip\mcc18\lib" /l"E:\fdd_emu\sources" /k"D:\Microchip\mcc18\lkr" /k"D:\Microchip\mcc18\bin\LKR" "18f4525.lkr" "D:\Microchip\mcc18\temp\main.o" "D:\Microchip\mcc18\temp\lcd.o" "D:\Microchip\mcc18\temp\utils.o" "D:\Microchip\mcc18\temp\hardware.o" "D:\Microchip\mcc18\temp\sdcard_lba.o" "D:\Microchip\mcc18\temp\clearblock.o" "D:\Microchip\mcc18\temp\fastspi.o" "D:\Microchip\mcc18\temp\fast_int_handler.o" "D:\Microchip\mcc18\temp\fat.o" "D:\Microchip\mcc18\temp\browse.o" "D:\Microchip\mcc18\temp\hfe_file.o" "D:\Microchip\mcc18\temp\ihm.o" "D:\Microchip\mcc18\temp\floppyemulation.o" "D:\Microchip\mcc18\temp\floppypinsstate.o" "D:\Microchip\mcc18\temp\browse.o" "D:\Microchip\mcc18\temp\fat.o" "D:\Microchip\mcc18\lib\clib.lib" "D:\Microchip\mcc18\lib\clib_e.lib" "D:\Microchip\mcc18\lib\p18f4525.lib" /u_CRUNTIME /o"pic2.cof" /M"pic2.map" /W
MPLINK 4.20, Linker
Errors : 1
i do not know how this is repeated?
thanks again for your help
i did what you said
it compiles ok
i get this message
MPLINK 4.20, Linker
Errors : 1
Link step failed.
MPLINK 4.20, Linker
Errors : 1
i don't know. try to compile from the website firmware zip file.gem1144aaa wrote:Hi Jeff
i did what you said
it compiles ok
i get this message
MPLINK 4.20, Linker
Errors : 1
Link step failed.
MPLINK 4.20, Linker
Errors : 1
gem1144aaa
hi Jeff
with your help and a lot of work i could finally build and get a hex file typical to yours.
now my problem is when i choose an image file witch is an image of a 3.5" 1.44mb stranded dos formatted floppy that created using the order
" disk2fdi a: e:\my_file /h2 /sst18.2 "
the emulator responds "Bad file" to my_file and also for the images found on you site
i didn't stop
i traced your code and i found the test
in the file named floppyemulation.c as follows
if(sectorBuffer[0]=='H' && sectorBuffer[1]=='X' && sectorBuffer[2]=='C' && sectorBuffer[3]=='P')
i just added the following statements before the test to insure that its result is true so it looked like this
sectorBuffer[0]='H' ;
sectorBuffer[1]='X' ;
sectorBuffer[2]='C' ;
sectorBuffer[3]='P' ;
it accepted the file and i got the following
T:51 S:121 Br:25
how come the number of sides to be 121 ?
and wher is the problem?
thankx again Jeff
i didn't stop
T:51 S:121 Br:25
thankx again Jeff
gem1144aaa wrote:hi Jeff
i didn't stop
T:51 S:121 Br:25
thankx again Jeff
You need to use this software to convert your images files to the hfe file format ( the only one supported by the sdcard emulator) :
(this must work without your code modifications)
gem1144aaa
