Jumper Confusion
ChrisCwmbran
Jumper Confusion
Post by ChrisCwmbran »
Hi all,
I'm using an HxC rev C with a Camputers Lynx. I want to connect a physical 5.25" floppy drive as drive B: and have the HxC as drive A:.
The cable I have has a twist. The HxC will be connected to the header nearest the computer i.e. pre the twist.
The floppy drive will be connected to the furthest header from the computer i.e. post the twist.
I am confused about the jumper setup for the HxC, and the correct ID to jumper the physical drive as.
Can someone help please?
Thanks in advance!
Chris.
ChrisCwmbran
Re: Jumper Confusion
Just as an additional note I'm assuming the floppy drive being at the end of the cable will need it's terminating resistor fitted?
This is in the user manual :
In shugart systems : DS0 = ID0-X,DS1 = ID1-X,DS2 = ID2-X
X = emulator virtual drive A or B
