Problem with STM32 Flasher
skel2raw
Post by skel2raw »
no matter how often I tried, the STM32 Flasher program just won't show "device decteded" so that I can flash. It just shows "link is up".
However, if I flash the software from Harve Messenger with the STMicroelectronics Flash Loader Software it works right away without any problems.
Please advice on how to solve the problem.
Thx!
Re: Problem with STM32 Flasher
Server restarted.
Just retry.
skel2raw
Post by skel2raw »
Status still stays at "Link is UP!. TX and RX are slowly counting up. Status for the serial port is "serial interface set to COM7".
skel2raw wrote:Status still stays at "Link is UP!. TX and RX are slowly counting up. Status for the serial port is "serial interface set to COM7".
both RX and TX ? Sure ?
COM7 is the usb serial interface ? Sure ?
Try to reset the device.
skel2raw
Post by skel2raw »
yep both, RX and TX are counting up simultaniously. And yes, COM7 is the usb serial interface, also a reset several times.
skel2raw wrote:yep both, RX and TX are counting up simultaniously. And yes, COM7 is the usb serial interface, also a reset several times.
Is it possible to have a picture of your connections ?
skel2raw
Post by skel2raw »
I have tried another USB adapter today and now it worked. Thanks for your help!
skel2raw wrote:I have tried another USB adapter today and now it worked. Thanks for your help!
ok fine!
:D
teevee
Post by teevee »
Which USB adapter did you use to make it work?
Dss2
Post by Dss2 »
So is it the case that the STM32 flasher won't work with 64 bit windows 7 or is it dependent on the serial interface?
Dss2 wrote:So is it the case that the STM32 flasher won't work with 64 bit windows 7 or is it dependent on the serial interface?
It work in windows 7, but some low cost usb serial adapter seems to have buggy driver for windows 7....
The same serial interface seems to work on windows XP and others serial interfaces work on both OS...
Dss2
Post by Dss2 »
I bought a ttl flasher off of ebay with a pl2303 prolific chipset.
Turns out that it does work fine in windows 7 64 bit mode.
I've flashed 4 goteks now. (One goes in an emax 1, one may go into an rm1x, and then I have a couple DSS1s.)
The emax 1 one is working great.
