ASR-10 can load system from HxC, but saving fails
creuset
Post by creuset »
Just got my GOTEK flashed with latest HxC installed in my ASR-10.
It was able to load the system from USB drive no problem, so I formatting a disk so I could save to it. (I made a few other copies of the system disk on the USB drive)
It seemed to get about halfway done and the show "FILE OPERATION ERROR".
This is the error I would get when a disk was corrupted while I had the original floppy drive in there. it meant that disk was no good and had to be tossed.
i'm trying with other USB sticks, but no luck yet.
I've been able to load instruments from files made from floppy images, but I haven't been able to try saving since they're all full. the OS disk has a little free space, so i could try recording & saving a short sample on that.
I only have the "M0" jumper set on the GOTEK.
It seems to be the same problem in this thread. i guess i need to make an image from a blank formatted floppy?
https://hxc2001.com/floppy/forum/viewtopic.php?f=17&t=749
Image - OS loads just fine!
Note : none of my USB 3.0 drives are detected by the Gotek. the screen just says "Hxc" and USB drive's activity LED blinks constantly.
Re: ASR-10 can load system from HxC, but saving fails
creuset wrote: the OS disk has a little free space, so i could try recording & saving a short sample on that.
Yes please try this.
Zetel
Post by Zetel »
I have the same issue with my gotek usb drive...i can load any os without any problem..but when i start saving i take a operation error...on any hfe file i have....what is my problem?
Zetel wrote: Sat Dec 16, 2017 2:21 am I have the same issue with my gotek usb drive...i can load any os without any problem..but when i start saving i take a operation error...on any hfe file i have....what is my problem?
if not already done try to update to the very last firmware version (>3.1.0.X)
VictorNess
Post by VictorNess »
The ASR-10 can load systems from HxC successfully, but saving often fails, which can be quite frustrating. This issue can hinder users from creating unique sounds for their projects, much like the distinct audio elements found in games like fnaf that enhance the overall experience.
