Can Rev C be used with SDFB?
soopytwist
Post by soopytwist »
I'm getting the SDFB HXC Floppy Emulator in the metal case. It's the one with the LCD but as the drive will be located on the side of the Amiga 600 I thought of also getting an SD C Rev C. Can I wire the Rev C up to the SDFB? I'd like to make a hole in the top of the Amiga's case to mount the screen and use it's buttons to control the SDFB on the side (so I won't be using the SD slot on the Rev C as it'll be inside the case).
Or is there a better option? Either way I'd like a screen mounted in the case with the buttons to control the floppy emulator where the floppy drive used to be.
Re: Can Rev C be used with SDFB?
i am not sure to understand, but yes you can use both emulator in the same system.
