Aligent 4402 floppy issues
john361
Post by john361 »
I fitted a slim SD card floppy to my Agilent 4402 analyzer but it says bad tracks or not fitted, I have loaded the card with the relevant files and the CFG file which does work when set for no volume on the sounder it responds correctly. The standard 1.44M floppy works fine so it's not a problem elsewhere. any suggestions would be appreciated. I have tried all dip switch settings all files are st for PC 1.44M floppy
John
Re: Aligent 4402 floppy issues
john361 wrote:I fitted a slim SD card floppy to my Agilent 4402 analyzer but it says bad tracks or not fitted, I have loaded the card with the relevant files and the CFG file which does work when set for no volume on the sounder it responds correctly. The standard 1.44M floppy works fine so it's not a problem elsewhere. any suggestions would be appreciated. I have tried all dip switch settings all files are st for PC 1.44M floppy
John
Please contact me there :
