Random Read/Write issues when using Workbench/AmigaDos disks
Ricky2u
Post by Ricky2u »
Hi All,
Just recently updated my Gotek with the great HxC firmware and I have noticed a issue with certain types of ADF images.
For example if I select C64 Tracks ADF from TOSEC Music demos and assign it to slot 1 and save/reboot I sometimes get a Read/Write error during boot up of the disk or when its within the program running.
I have noticed if I turn off my Amiga 500 for 10 seconds it may fix the read/write error and continue to load the program like normal. This may work for a while and then when changing slots I get the error again.
My Gotek does have the sound mod included and I am not sure if its the Gotek or the CIA chip on my Amiga, I have tested a 32gb Sandisk USB2 and a USB3 micro 64GB Sandisk.
Both have the same symptoms.
The worst I have seen is when the floppy emulation will load as normal and I can select files and load then for about 3 - 4 minutes. Then I get read write errors on anything i try to open.
Anyone else had this issue and fixed it?
Thanks in advance.
Re: Random Read/Write issues when using Workbench/AmigaDos d
This look like to be a virus problem.
Many of your adf/hfe are probably corrupted/infected by a bootsector virus, even the autoboot.hfe.
Ricky2u
Post by Ricky2u »
Thanks for your prompt reply, I will try some decent anti virus tools and see if I can identify a infection.
Cheers.
Ricky2u
Post by Ricky2u »
Just a update, I ran master virus killer on multiple ADF images on the Amiga 500.
No infection found in memory or disks.
So I did a test and turned off the Amiga for 1 minute and then loaded the autoboot menu (checked for viruses as well all clean).
I selected a copy of Rainbow Islands that I know is working and it worked fine the first run without issue.
Next step to test if it was corruption of the USB drive I just then warm rebooted the Amiga with the same slot.
I then had issues with the levels loading asking me to insert the Rainbow Island disk. I had turn off the machine for 10 seconds and started the game again. This time it loaded a little further and asked for the disk again.
Thinking it was now corruption I went and took out the USB flash drive and compared the CRC of the file having issues and my working backup on my PC. I can confirm that both CRC's are identical.
I am now thinking that this maybe a hardware issue. (tested two different USB sticks)
Tomorrow I will try swapping the CIA chips around and see if the issue persists.
Cheers.
norb
Post by norb »
I can test it ADF, but please specify files
It seems to me that all the time you have a virus on a floppy disk or memory
Ricky2u
Post by Ricky2u »
Just took out the buzzer mod and it appears the Gotek is more stable. Got Fire and Ice working after a warm reboot without disk errors.
I will continue testing.
Ricky2u
Post by Ricky2u »
New update: appears all issues are now resolved.
I have replaced the autoboot file due to corruption and now all disks are working even when doing a warm boot or changing slots.
So it was the sound mod that coursed some form of data corruption.
Thanks all.
Ricky2u wrote:New update: appears all issues are now resolved.
Thanks all.
Yes, please avoid these sound mods hack... Most the schemes draw too much current and/or add to much capacitance on the track step line. The signal integrity is seriously a problem.
I will add the sound support on the next firmware version. the buzzer will be connected on the JA jumper.
