Gotek, Write Issue?
rfancella
Gotek, Write Issue?
Post by rfancella »
Hello all,
I am using a Gotek with the HxC firmware in AutoBoot mode.
Yesterday it was working fine. Today, when the Amiga Manager starts, I get "LBA Change Test Failed ! Write Issue ?".
I have tried changing the firmware to the Cortex and then back again with no change. I even get an error with the Cortex firmware.
It boots and works fine on my Atari 1040 STf. But moved over to my Amiga 500, I get the above error.
I am using the same USB drive for both, just changing the AUTOBOOT.HFE and the HXCSDFE.CFG files.
What should I be looking for?
Any help would be great!
ron
Re: Gotek, Write Issue?
have you tried another Ffloppy ribbon ?
On the ST the manager is working fine ?
rfancella
Post by rfancella »
Jeff,
Yes, the ST side is perfect.
On the Amiga side, it errors when the Amiga manager is trying to read the USB stick. It works just fine in Indexed Mode.
I will try a different cable. I also have a couple new USB drives on their way.
Ron
Jeff wrote:have you tried another Ffloppy ribbon ?
rfancella
Post by rfancella »
Jeff,
Maybe a corrupt USB drive?
I tried the stock A500 floppy cable and the same result.
I will backup all the stuff on my USB drive and do a format and re-copy. See if that fixes it.
Ron
rfancella
Post by rfancella »
Ok,
A couple updates. Not sure if they will help or not.
It does not seem to be the cable at all. It also does not seem to be a bad USB drive.
I did discover this: If I boot it in Autoboot mode it will error out from a cold start. If I Ctrl+A+A it works every time.
I have tried this with the download from the website and the beta also. They both act the same.
I have ordered another Gotek to see if that is the issue.
Ron
rfancella
Post by rfancella »
Ok,
Got another Gotek in and flashed. It seems to be an issue with the old Gotek.
Another question. I would like to use one for DF0: and one for DF1:.
I thought I saw a post somewhere that referenced this. Right now, I have to swap the two, program it and then swap them back.
Is there an autoboot.hfa that I can put on DF1: and run it to program it? If I try to run the existing one, it programs DF0:. ;)
It would be nice to have the program on DF1 that I can run and save the list. And exit back to Workbench. ;)
Ron
