Files in ST and STX
vindicator
Files in ST and STX
Post by vindicator »
Hi! I buyed a SD HxC Floppy Emulator REV C. I'm using the last firmware 1.8.4
When i use the software and convert ST to HFE o STX to HFE (stx is not working fine..) in HFE i can load the images. But if i use ST images directly in the SD card, the hxc says "bad file!".
What happen?
Thanks!!!!
Re: Files in ST and STX
Nothing anormal there since the SD emulator only take the HFE format.
Fot the STX support, try the latest software version :
