Any ideas for EPM7128SLC84 replacements
petersieg
Post by petersieg »
Hi.. the cpld EPM7128SCL84 is not easy to optain.. discontinued.. and the price tag is getting higher..
Are there any ideas to possible replacements?
Newer cpld.. adapter socket..?
Or probably new board design with actual cpld?
Just a question..
Peter
Re: Any ideas for EPM7128SLC84 replacements
petersieg wrote:Hi.. the cpld EPM7128SCL84 is not easy to optain.. discontinued.. and the price tag is getting higher..
Just a question..
Peter
No replacement in PLCC package.
Lot of replacement in cms (MAXII devices for example), but it's harder to solder (100-144 pins 0.5mm pitch etc)
But MAX7000 isn't descontinued !?!:
http://www.altera.com/products/devices/ ... index.html
http://www.buyaltera.com/scripts/partsearch.dll?PV-6=11
http://www.buyaltera.com/scripts/partse ... -1208-5-ND
petersieg
Post by petersieg »
Hi Jeff.
Are these CPLD's also useable for HxC USB?
-> ATF1508AS-15JC84:
http://cgi.ebay.de/ATMEL-CPLD-ATF1508AS ... 0011302853
(BTW: The price is to high.. Just that I know I can use these chips as well..)
Thanks, Peter
petersieg wrote:Hi Jeff.
Thanks, Peter
very interesting!
This device seems pin-to-pin compatible with the epm7128 and is a 5V part! So this is electricaly compatible!
But i don't know if this device is 100% equivalent to the epm7128 (i didn't found the information on the net)
(EDIT: i have found the information here : http://www.atmel.com/dyn/resources/prod ... OC0916.PDF
So this the device is compatible ! : this a chip that we should test.
(the price is lower there : http://search.digikey.com/scripts/DkSea ... S-7JX84-ND)
More informations about this chip here :
http://www.atmel.com/dyn/products/produ ... rt_id=2130
petersieg
Post by petersieg »
Hmm. Jep. That seems to be a replacement for Altera EPM7128 made by Atmel..
>(the price is lower there : ATF1508AS-7JX84-ND)
They mention 96 I/O ports.. that can't be right..?! PLCC84=84 PIN's!?
Anyway, the ATF1508AS-10JU84-ND costs app. 12€/piece.
The above -7JX84-ND only app. 6€/piece.
The cheapest EPM7128 I could find was at segor for app. 20€/piece.
Also I don't know, if the Atmel chips can be programmed with Altera Byteblaster??
(So many questions..)
Peter
lotharek
Post by lotharek »
Just testing ATF1508AS with USB version..
Simple BYTEBLASTER MV is enough to programm under atmelISP.
POF file converted with POF2JED...
but so far no effects
Software says EMULATOR NOT DETECTED nevertheless led is indicating connection to PC...strange
..... Atari Roxxx !!!
lotharek
Post by lotharek »
i confirm - 1508 works
CrazyIcecap
Post by CrazyIcecap »
Really? Cool...what was the problem?
CrazyIcecap wrote:Really? Cool...what was the problem?
a soldering problem ;-)
i will add the atmel programming file and add it in the BOM.
lotharek wrote: geeeeee
You are right
works now ;-)
stupid mistake
ps. atf1508 works :-)
also, for programming i recommend atmelisp - free download form atmel
www and BYTEBLASTER MV --- simple programmer build of 244hc and few
resisitors
> hi,
> i have see on the forum that the ATF1508AS works on the hxc floppy emulator
> board.
> what was the problem ? could you send me the good jedec file ?
hello
reason it didn`t work was my stupidity....
i was tired (very very) and have`nt soldered fti chip ;-)
I tested on amiga and PC
lotharek
Post by lotharek »
btw: does anybody over here have a kickstart 1.3 disk for amiga 1200 to assure compatibility with a500 ???
please, let me know lotharek@mmj.pl
average_male
Post by average_male »
lotharek wrote:i confirm - 1508 works
Hi lotharek and/or Jeff,
What is the minimum setup to program the ATF1508? Does one need the decoupling capacitors? Of just the wire up all the VCC and Ground connections and the JTag pins to the CPLD and all should work? Also, does one require a 5V source or will the ByteBlaster uppply that via JTag VCC pin?
Moe
average_male
Nevermind, I got it.
For completeness and for those that are interested:
1 - CPLD (AFT1508AS)
8 - decoupling capacitors
1 - ByteBlasterMV
1 - 5V power source
One important note: your programming cable "ByteBlaster" should not exceed 6 feet and don't use a LPT parallel cable between computer and CPLD/Dev board.
lotharek
Post by lotharek »
decoupling capacitors are for your safety.
i use 4 metres long lpt cable and works
byteblaster - homemade lotharek version. looks shit but works.
at picture my first "bought" programer - i fried him after some tortures.
