SD Card Emu Antrobot revision Thanks Jeff.
emrez
Post by emrez »
add Antrobot asm programmer;
** sd card empty - print lcd sd card empty
** 16x2 lcd or 16x4 lcd select
** dir 16x4 4 file name list display /16x2 2 file name list display
** eject button
** to add reset (eject + next button to press reset)
** print lcd select file amiga or select file pc
** eject button press back folder.
** add sd change
** print lcd side and total track
** add manuel jumper amiga or pc 2-34 pin change
** little supplies and change microchip 18f4620
** image name.fdi read fdi "floppy disk emulator"
Antrobot next revision pal options and file name a-z list. Thanks Jeff. Thanks Antrobot.
16x4 sample
workbench.fdi
track xx
x side run amiga file
total track xx
>Work.fdi
oktalyzer.fdi
extras.fdi
dos6_pc.fdi
Re: SD Card Emu Antrobot revision Thanks Jeff.
Sorry but :
-> already done in the new version.
** eject button
-> Useless in the new version.
-> Done
** add sd change
-> Why ? You can changed the sdcard in the new version
-> Why ? the software choose this automatically in the new version ?!
-> already done here :https://hxc2001.com/floppy/forum/viewtopic.php?t=163
-> what is a fdi file ?? can you explain me ?
and emrez please don't forget that :
Copyright (C) 2006, 2007, 2008 JFDN
This file is part of HxCFloppyEmulator.
HxCFloppyEmulator may be used and distributed without restriction provided
that this copyright statement is not removed from the file and that any
derivative work contains the original copyright notice and the associated
disclaimer.
HxCFloppyEmulator is free software; you can redistribute it
and/or modify it under the terms of the GNU General Public License
as published by the Free Software Foundation; either version 2
of the License, or (at your option) any later version.
HxCFloppyEmulator is distributed in the hope that it will be useful,
but WITHOUT ANY WARRANTY; without even the implied warranty of
MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
See the GNU General Public License for more details.
You should have received a copy of the GNU General Public License
along with HxCFloppyEmulator; if not, write to the Free Software
Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA
emrez
Post by emrez »
Jeff help message;
Private messaging has been disabled on this board.
Quote:
https://hxc2001.com/floppy_drive_emulat ... _PIC_c.zip
https://hxc2001.com/floppy_drive_emulat ... ft_PIC.zip download /c versiyon pcb and systematic not learned.
-> sample; dosboot.ima select
16x4 lcd print dosboot.ima
insert pc file
change pc file code Antrobot change code
unintentionally, not commercial.
emrez wrote:Jeff help message;
insert pc file
mhhh not commercial.... that's why you have made at least 20 pcb...
http://img98.imageshack.us/img98/6969/2 ... 139rn7.jpg
In fact, i don't understand what are you doing. From my point of view it seems that you have "cloned" the project without motion that you have based your works on the HxC Floppy Emulator, according to this thread on amiga.org forum and video/pictures on commodore.gen.tr :
http://www.amiga.org/modules/newbb/view ... 02&forum=8
And copyright statement should not be removed, whatever the status of the project.
i hope that i am wrong.
emrez
Post by emrez »
Make one emulator my friend Özkan.
Not sale emulator. money not to need.
make 14 pcb min.
Jeff I am writing turkish . Türkçe bilsen harika olurdu.
emrez wrote:Make one emulator my friend Özkan.
make 14 pcb min.
ok but i didn't understand turkish (no translator on the web...)
moghul
Post by moghul »
HI ALL
i m here in first time. i want to make sd card to floppy emulator. please tell me is ur system working well? i want to use it on normal pc.
please help me in this.
i shall be thankful to u all.
moghul
MOGHUL
