Gotek HxC Firmware and Dragon 32
mcSDHXC
Post by mcSDHXC »
Hi.
Has anyone managed to get this combo working? I have tried Normal and Indexed mode with no success. I have even tried adding Dragon files (converted to HFE) to the slots using the Atari ST config files and Autoboot.
Nothing seems to work..
Re: Gotek HxC Firmware and Dragon 32
mcSDHXC wrote:Hi.
Yes this is already used into the Dragon 32.
Some questions :
Firmware version ?
Have you an LCD ?
How did you connect the device ?
mcSDHXC
Post by mcSDHXC »
Hi Jeff
Firmware: 3.0.6.2a
3 digit LCD display - No IC2 LCD screen (although I have one on order)
Connected to dragon using straight cable. Jumpers M0 and S0 set.
USB key (Cruzer 8GB) tested in Gotek on other devices and works perfectly.
CaptainKirk
Post by CaptainKirk »
@ mcSDHXC - Did you get the issue resolved?
I've got a Dragon 32 as well and I want to get a Gotek drive for it.
But I don't which is correct for me because there are many variants on ebay.
I would be grateful for any advise.
Also what is the correct interface cable that I need to get?
Thanks.
