Can't enter direct access mode from HD image (HxC Gotek)
bjt
Post by bjt »
HxC Gotek, firmware 3.0.6.0a
If I start up the file selector app when a HD image is selected, the Gotek fails to enter direct access mode.
This doesn't happen if I start the selector when a low-density image is selected.
When the Gotek fails to enter direct access, the display changes to the direct access mode for a second, then back to displaying the slot number, then back to the direct access mode.
Cheers,
Ben
Re: Can't enter direct access mode from HD image (HxC Gotek)
Acknowledged.
bjt
Post by bjt »
Just to update, I tested the latest firmware 3.0.6.2 and this issue is still happening. Let me know if I can help to track it down , run tests etc. Thanks
bjt
Post by bjt »
Still happening with fw 3.0.8.1a. This happens on the Slim hardware too.
Another user report of this bug: http://www.vogons.org/viewtopic.php?f=2 ... 16#p491964
My HxC slim and 3x Goteks are working great otherwise :-)
