601 Seek Test POST error on IBM XT (HxC Gotek)
bjt
Post by bjt »
Hi Jeff
I have my HxC Gotek connected to an IBM XT.
During boot the XT performs a seek test.
Occasionally, the seek test will fail and return a 601 error.
The seek test performs the following:
- Spindle motor on
- Seek to track 0, if error stop spindle and return 601
- Seek to track 34, if error stop spindle and return 601
Regardless of the 601 error the Gotek works in DOS.
Any ideas? Thanks
Re: 601 Seek Test POST error on IBM XT (HxC Gotek)
bjt wrote:Hi Jeff
- Spindle motor on
Any ideas? Thanks
Are you using the latest firmware version ? (3.0.6.0a)
Are you using the direct access mode before this error ?
bjt
Post by bjt »
Yes, this still occurs with 3.0.6.0a.
It happens from a cold boot (no direct access beforehand).
I have been trying to find a pattern to the 601 errors.
Most of the time they seem intermittent.
However, at one stage I had a repeatable case where:
- No USB stick inserted: 601 error
- USB stick inserted, valid image selected: no 601 error
However, I have since had cases where I see 601 with an image selected.
Is it possible that the Gotek isn't responding to the POST seek commands quickly enough?
bjt
Post by bjt »
After some experimentation, I think the XT BIOS floppy POST is only compatible with original IBM floppy controllers. The 601 error doesn't happen with the original controller, only with a third-party controller. So, I don't think it's anything to do with the Gotek.
I've bypassed the floppy POST now = no errors 8)
