Hi all
I am having problems trying to run DPX tools on a Windows 7 virtual machine (Parallels Desktop) which is running on my iMac. The first line in the e2dpx.exe screen reads "ERROR: incorrect parameter list". The last line reads 'Press a key...' I hit a key and the e2dpx.exe screen disappears.
As there is no internal floppy drive installed in my iMac, would that have something to do with the above issues? I did install the FDRAWCMD.SYS floppy driver in the windows virtual machine by the way.
Any advice on the above issue would be greatly appreciated.
Cheers
DPX tools problems
DPX tools problems
- e2dpx error.tiff (47.93 KiB) Viewed 6825 times
Re: DPX tools problems
I didn't have developed these tools so i can't help you with them.
What are you trying to do exactly ?
I have finally worked out how to convert the files. You don't double click e2dpx but for batch conversion you can make a small file in notepad E2DPX.BAT and type a line of text in that BAT file: e2dpx.exe B. When you run the BAT file by double clicking it, it will convert all the EII files to DPX. Then you have to convert them obviously to hfe in order to run them in HXC.
would you mind elaborating on how you do this step by step? I am having the same issue, trying to convert EII files to DPX, using a Mac running VMWare
WHere do you put the original files youre trying to convert? Unclear as to the order of events
thanks!
EDIT - Figured it out! For any future humans looking at this
Step 1. locate your folder of .EII files
Step 2. Place the E2DPX exe app in that folder
Step 3. in Windows "Notepad" create a file called E2DPX with the text mentioned previously in the body of the text.
Step 4. Save as a .BAT file
Step 5. Double click that file
Conversion!
thanks!
Conversion!
