I have a Gotek with latest HxC firmware in an IBM XT.
I can write 720k/DD format images to the USB stick from a Windows PC and read them on the XT, no problem.
I can write files to an image on the XT too.
However, if I try to copy/read the files that were written on the XT, I get "Data error reading drive A".
Have tried 2 different USB sticks, no change.
Will try a new floppy controller shortly.
Will also try a 360k image, in case it's related to data rate.
Any other ideas? Thanks
Data error after writing (HxC Gotek)
Re: Data error after writing (HxC Gotek)
I should also add that after writing to the image on the XT, the image is no longer readable in the HxC software in Windows - it gives an error about bad sectors. Will check the exact error message later.
Yes i got this issue some days ago. I will work on it next week.
Anyway please share your corrupted HFE file.
Here's a corrupted HFE. I get data errors when reading COMMAND.COM. Thanks
- AUTOBOOT.zip
- (218.79 KiB) Downloaded 689 times
Update - I tried another floppy controller, no improvement.
I have a 1.44MB corrupted image (windows HxC tool won't load it) but it's too big to attach.
Let me know if you want me to email it.
The latest firmware solve these issues. (3.0.6.0a)
Tested this and it's now working great. Thanks!
