hxc floppy emulator opens autoboot but no games are present
gorgos10
Post by gorgos10 »
hallo hxc works ok with my 1040stfm but in cpc 6128 after i open the hxc manager ,when i open a games folder it stucks for a while with no games found and it goes afterwards to the game folders again.used to work fine,the only change i made is to buy a couple of silicon power micro sd cards to put the games but no solution!
maybe incompatability of micro sd cards,ribbon cable or something?firmware is 182.140 latest....
Re: hxc floppy emulator opens autoboot but no games are pres
No game found? Where ?
gorgos10
Post by gorgos10 »
inside the alphabetically sorted a-z game folders.it shows them empty although i see them fine in windows .i bought a second new micro-sd card (silicon power brand)but nothing....
Is your games images in HFE format ?
gorgos10
Post by gorgos10 »
no i said i had problems with the cpc 6128 emulation not the atari st one.the images are in .dsk format and were working fine since i used them every day....
You need to have them in HFE format.
Use this :
