File Selector menu for the BBC Micro/Master
siskodata
Post by siskodata »
Is there a file selector menu program for the Acorn BBC like the ones available for the Amiga, Atari and Amstrad?
Or at least an easy way to select the floppy you want to use through the LCD and buttons while preserving the name of the floppy image.
I am using a Gotek HXC with 16X2 i2c LCD display
Thank You
Re: File Selector menu for the BBC Micro/Master
The LCD selection is your best bet. :wink:
siskodata
Post by siskodata »
Yes it would be ok just to use the LCD but you have to change the names of the disks to DSKA0000.hfe, DSKA0001.hfe, DSKA0003.hfe........ etc and cannot keep the original name of the disk image.
