Korg I2
arkimede
Korg I2
Post by arkimede »
Hi Jeff!
Updated Gotek to new firmware version 3.0.4.0
Using new names (DSKAnnnn) works! (the display cycles through the images)
- the right button advances by one
NOTE: the left button moves back but with "fast repeat" - it seems missing debouncing/one shot
Question1: if I push both the two buttons nothing particular happens. is this correct or they have a function? (i.e. select)
If I am not mistaken the Gotek drive use button 1 to advance units, button 2 to advance tens and both button to advance hundreds; there is not back button but, in my opinion, this mode is faster to move from 491 to 22 or vice-versa :)
Question2: if I connect the lcd display and deselect indexed mode can navigate through image names and/or diskette labels ?
Note about installation on Korg I2:
Replaced the original 720kb drive ALPS DFR423F02A
Created images with HxcFloppyEmulator v2.1.1.0 beta
file system: 720kb DSDD FAT 12
The keyboard READ disk catalog
BUT
fails ANY loading with "no disk in drive"
same error also writing data to an empty image
the green led is always on (also when no disk operations)
Any suggetsion?
Thank you
Re: Korg I2
Try to change the interface mode of the HFE file . Try the shugart mode (open it , set the interface mode to Shugart , reexport it.)
arkimede
Re: Korg I2
Post by arkimede »
Jeff wrote:Try to change the interface mode of the HFE file . Try the shugart mode (open it , set the interface mode to Shugart , reexport it.)
SHUGART MODE WORKED!
Let me know if you solve back button issue or other questions
Thank you
(finally i can play my korg :) )
tonyvfish
Re: Korg I2
Post by tonyvfish »
I wonder if you could help I have an i3 that I'm trying to emulate the floppy for. I am currently using Gotek 1.44 floppy emulator and incase image software and getting no disk inserted. I made the images as 720k any information appreciated
Re: Korg I2
Is this HxC related or not ?
