Gotek and i2c lcd display ?????
lupo2110
Post by lupo2110 »
i have connected an i2c lcd display to an gotek usb floppy emulator.
Flashed newest Firmware USB HxCFloppyEmulator v3.0.3.1a.
I have connected 5v, ground on the programming connector on gotek
Also i have connected sda, scl with 4.7k ohms resistors on jumper j7 on gotek.
So the display goes on and nothing else happens.
I have tested without resistors with the same result.
Does the gotek emulator functions with i2c lcd display as mentioned in the firmware release notes txt ?????
Best regards
lupo2110
Re: Gotek and i2c lcd display ?????
Post by lupo2110 »
Please note that 2 additionnals 4.7Kohms pull up resistors (+5V) are needed on SCL & SDA.
So pull up +5v means: one end of 4.7k resistor to 5v and the other end to scl & sda connections ????
Is that right ???
I also have tested this but the same result: display goes on and no output ????????????
Any help appreciated ?????
I have taken this display:
http://www.amazon.de/gp/product/B00855Z ... ge_o00_s00
i think its the same as in the txt mentioned.
lupo2110
Post by lupo2110 »
Update:
With the help of jeff the sainsmart lcd display works fine.
An modified gotek firmware is needed to communicate with such display.
Thank you very much
Best regards
Solved by email. New version incoming.
siskodata
Post by siskodata »
lupo2110
Did you still use the pull up resistors?
I have a similar display but get the top line all switched on and the lower is all off.
This is my LCD
http://www.ebay.com/itm/321558542340?_t ... EBIDX%3AIT
It is similar to yours as it uses the same PCF8574T
lupo2110
Post by lupo2110 »
Yes pull up resistors have to be installed but this is needed to enhance the signal quality in the sda and scl lines.
Perhaps your display has a defect ?!
siskodata
Post by siskodata »
Thanks for the help
Works perfect with version 3.0.4.0a
danko
Post by danko »
Hi Jeff! i have a I2C board + LCD display how to connect the wire?
Connected VCC and GND on the programming connector
SDA and SCL on the J7 position
But when turn on amiga display do not appear characters,see photo.
http://i742.photobucket.com/albums/xx61 ... g~original
danko
Post by danko »
danko wrote:Hi Jeff! i have a I2C board + LCD display how to connect the wire?
Any news for my problem? :?
Am i supposed to have news about this ? ;)
I don't see the pull resistors on your picture and i don't see which I2C module you are using too, so i have no news since i don't have enough information to make any answers. So please make more pictures
xadox
Post by xadox »
Since I am no expert I am using such layout on a Stripboard for connecting the display:
It is working fine, but is it also right?
xadox wrote:Since I am no expert I am using such layout on a Stripboard for connecting the display:
if the read wires is the resistors, yes this is correct.
xadox
Post by xadox »
Thx.
