Emax loads disk but not all samples
baron
Post by baron »
I purchased the Rev F back in 2014 for my Emax and have only now gotten around to installing it and I'm experiencing a few issues.
I believe the jumpers/cabling is correct as the Emax recognizes the HXC and will load disks, but it skips samples. I've tried the sample .hfe's 'mixed chorus' etc. and I still have this problem.
The unit I have has the SE stickers attached to the front, so it appears it to be the SE however when I received it, it displayed os boot disk required. Maybe the SE os wasn't installed properly? I don't have access to a desktop computer with a floppy drive to write an seup disk, so hopefully this isn't the problem!
I've tried SE os 1.1 and 4.0, as well as the regular emaxos.emx
I think I have followed the correct formatting procedure...
Any thoughts?
Re: Emax loads disk but not all samples
First have you the latest firmware version ? :
http://www.youtube.com/watch?v=7XUwg-7sDY4
Which SDCard Brand & model are you using ?
Did you a have a particular error message at the Emax ?
baron
Post by baron »
Thanks for the prompt reply!
I tried updating firmware, no changes.
The SD card is a Kingston SD HC 32gb.
No error message is displayed. When loading a bank the Emulator will make it's tapping sound as it counts up and then beep and skip a bunch of numbers before continuing to count and stops at 73/80. At this point I can then choose from samples 1-17 and 98-99 for example.
I am not sure what is going on, but regarding your description it seems that there is something wrong with the SD.
I recommend you to try another sdcard model (Sandisk Class 10 recommended).
baron
Post by baron »
Ok will do. Thanks for the recommendation.
baron
Post by baron »
Unable to obtain a Sandisk card where am I at the moment. I've tried a nexxtech 16gb Class 10 with the same results.
Maybe it is a jumper issue?
It should be one of these two settings? Both produce the same results:
I'm not sure if technically the cable is 'twisted'. It does have a fold in it... ID03A on as in the first photo is correct for twisted cable?
I'm using OSX, but the SD card is formatted FAT32.
Your ribbon is not twisted, so the right setting is ID0-A (1).
baron
Post by baron »
OK cheers.
Will hopefully have a Sandisk C10 to test this friday.
Thanks Jeff!
starfield
Post by starfield »
any luck Baron?
i have the same problem
