So yes for sure the HxC will work
Compatibility with Korg Trinity
Re: Compatibility with Korg Trinity
A SD HxC mount the images a waaaay faster at power up than the Gotek having to deal with the whole USB stack.
@mathausen,
I've flashed my Gotek with HxC firmware and I can't load disks with the Trinity. I can see the files on the screen but each time I want to load one by touching the screen, the synth makes a disk refresh. Did you manage to make yours running ? Which configuration do you use ? Is DS1 jumper closed ? I personnaly use indexed mode. This works well. Which interface mode do you use, PC 1.44 HD, Shugart... ? Your help is welcome. Thanks
