I need update my HxC
mode2
Post by mode2 »
Good morning,
I want update the firmware of my HxC SD (v1.1.2.3) to v1.7.2.0. I've read that before i need v1.2.0.0, or its bootloader (HxC_SD_Bootloader_V1_0TOV1_1.upd). Where can download a reliable version?
Thank you!
Regards,
mode2
Re: I need update my HxC
Post by mode2 »
Hello again,
I need download this firmmare update. I've found it here:
http://www.nightfallcrew.com/13/07/2012 ... -released/
But, I am not sure that this file is correct and I can damage my HxC.
Please, I need help. :`-(
mode2 wrote:Good morning,
Thank you!
Regards,
Why do you want to update this firmware ?
mode2
Post by mode2 »
Because I wish use the autoboot with my CPC and I have problems. The SD HxC says that it can't access to SD when I execute hxc.hfe.
Thanks,Jeff.
mode2
Post by mode2 »
Can anyone help me? Please!
Thanks!!
mode2 wrote:Can anyone help me? Please!
Thanks!!
Help to do what ? You already have all you need.
mode2
Post by mode2 »
Thanks!!
Hello Jeff!
As I said, I 've found the firmware update on another web but I don't like getting off files unofficial sites. Is it ok?
mode2
Post by mode2 »
Finally I've updated to the 1.7.1.2 and when I execute the autoboot.hfe with run"Hxc in my CPC 6128 it displayed an error in the lcd (Direct access LBA 000000 08) and the cpc is reset.
What is the problem?
I've probed with 2.5, 3 and 3.1 manager version.
Thanks!!
mode2
Post by mode2 »
This is not an error.
Check you jumper setting & try the firwmare 1.7.2.0
mode2
Post by mode2 »
Hello Jeff!
I've the same 'problem'.
The HxC emulator is installed in the disk expansion port of my 6128 CPC. I've configured the jumpers as the first disk drive and I've disabled the internal floppy disk drive unplug the floppy cable from the internal disk drive. I've updated the firmware as 1.7.2.0 too.
This is my jumpers configuration:
