HxC Slim beep codes with direct access/file selector
bjt
Post by bjt »
I'm porting the Amiga file selector to DOS. When I select an image and exit the selector, the HxC tries to change to the new image (I think). However it fails and starts to beep repeatedly. The pattern is two beeps followed by a long pause.
I need to debug my code further but was wondering what this beep code means?
PS. Here's a pic to show current progress:
Re: HxC Slim beep codes with direct access/file selector
The cfg file probably don't point to the good HFE fat cluster. The emulator fail to read the HFE file.
bjt
Post by bjt »
Yep, that was it. (Short)DirectoryEntry requires explicit single-byte packing, as it has a long member at an odd offset.
Working great now, I'll spend some time tidying up the UI.
Docteh
Post by Docteh »
I was about to ask if anybody is actually using these for dos computers as I haven't seen any mention of a dos file selector. Looks great!
bjt
Post by bjt »
I'm hoping to release it within the next week or so.
bjt wrote:I'm hoping to release it within the next week or so.
If you have an sourceforge account, i can add you to the developper list.
bjt
Post by bjt »
Thanks Jeff, I am most familiar with github so I've put it up there.
bjt wrote:Thanks Jeff, I am most familiar with github so I've put it up there.
Ok. May i add it on the sf repository ?
bjt
Post by bjt »
Of course, go ahead
