I wonder if someone has succeeding in making it work for any of the the General Music S-series synths, in order to replace the original floppy (1.6MB disks) unit.
@ Rob Ocelot
Did you get it finally?
cheers
microkorg wrote:Hi everybody,
@ Rob OcelotI see you were trying to do it years ago.
cheers
To: Jeff
Sent: Monday, February 18, 2013 9:41 PM
Subject: Re: GEM S2 disk images
I solved the problem. I had the HxC configuration set to a specific bitrate, probably from when I was testing it with an SQ-80 a year or two ago. Setting the bitrate to 'from HFE file' fixed it. Jumper settings didn't seem to matter.
Thanks for your help and I'll update the forum post with the new information.
Regards,
Rob.
