Latest software?
spmac
Latest software?
Post by spmac »
OK i'm a little confused.
I just bought the latest REV F emulator direct from Lotharek.
http://lotharek.pl/product.php?pid=121
So REV F is the latest software for the emulator? & that is already installed on the unit?
If that's correct do I just need to put the SP1200 OS HFE file on the SD card?
I see a lot of links for it but there seams to be differant OS files?
Which is the correct/latest SP1200 OS file for Apple MAC users to put on the SD card?
Your help would be appreciated.
Re: Latest software?
You can find the archive to unpack to the SD for the SP1200 into this one :
spmac
Post by spmac »
Jeff wrote:Hi,
Thanks Jeff.
So do I unpack the whole SP1200 folder onto the SD card?
Or can the emulator navigate folders?
You can also navigate into folders. What i mean is that the files for SP1200 are into the SDHxCFE_Emu_SP1200.zip archive.
spmac
Post by spmac »
All good ...up & running! Thanks :D
