Support Flash Air SD cards
kitahei88
Post by kitahei88 »
Hello,Jeff.
Can you support Toshiba Flash Air SD card for HxC?
I don't test that card with HxC yet.
I think that uploading disk image to the card through Wi-Fi connection works Ok.
It doesn't depend on HxC functions. It's just Wi-Fi connection of PC and that cards.
I mean that Can you make HxC works with that card, mount or unmount images from PC ?
Do you know UNISDISK ?
It's drive emulator for AppleII , and work with Falsh Air cards fine.
This is how UNISDISK work with Flash Air cards.
http://tulip-house.ddo.jp/digital/UNISD ... ir_en.html
I want to use HxC like this .
Thank you.
Re: Support Flash Air SD cards
This should work but i never tried it.
