Long dead time after write operation
coredump
Post by coredump »
I found that the HxC2001 is dead after write operation for about 300 - 600 ms.
Some old 8-inch FD I/F doesn’t accept this condition. For example, write operation of the IBM FM format (not MFM) fails with the DSD 4140 for DEC PDP-11 (reading is OK). I think it is not a problem of the format of the disk image file because both reading and writing work with another 8-inch FD I/F.
I checked signals from/to the HxC2001. The HxC2001 doesn’t respond after rising edge of the WRITE GATE signal as shown in the linked file. The DSD 4140 seems to check INDEX pulses and/or READ DATA signals, and causes "no read data or drive not ready" error.
Is it possible to avoid long dead time after write operation?
coredump
https://www.dropbox.com/s/e8sxtlztcolsk ... e.jpg?dl=0
Re: Long dead time after write operation
coredump wrote:I found that the HxC2001 is dead after write operation for about 300 - 600 ms.
coredump
This delay is directly related to the write speed of the sdcard. Try to use class 10 SDCard (Sandisk Extreme Series for example).
The linked image seems to show a format process. There is maybe also a problem regarding the index signal state which may generate this error. Which firmware version are you using ?
BTW we are developing a totally different hardware design without this flash slow down effect.
coredump
Post by coredump »
Jeff wrote: This delay is directly related to the write speed of the sdcard. Try to use class 10 SDCard (Sandisk Extreme Series for example).
Thanks, Jeff.
I tried class 10 SDHC card but still have delay problem.
Jeff wrote:The linked image seems to show a format process.
Yes. Previous one is the format operation.
Jeff wrote:There is maybe also a problem regarding the index signal state which may generate this error. Which firmware version are you using ?
Linked image was of the beta firmware, V1_8_6_14a.
I installed v1.8.2.40 and got signals again as linked image. The RDATA signal doesn't come back in 4 ms.
coredump
https://www.dropbox.com/s/iji8nj43u47w7 ... 2.jpg?dl=0
Have you tried normal write (not format) ?
coredump
Post by coredump »
Jeff wrote:Have you tried normal write (not format) ?
My second post is not format but normal write.
coredump
And you still have error with write sector ? What is the write latency in this case ?
coredump
Post by coredump »
Jeff wrote:And you still have error with write sector ?
Yes. I still have problem in write operation.
I guess DSD 4140 controller requests valid RDATA within small time after rising edge of WGATE signal. This controller disables DRIVE SELECT 4 ms after rising edge of WGATE in my second post and generates "no read data or drive not ready" error.
4 ms ? ouch... i wonder what the controller expect with such small time. The write recovery time of some floppy disk drive are longer than this. For sure the sd / flash write completion can't be done into this period.
Anyway there is maybe a way to fool the DSD 4140 by sending a pattern during the sd write. Have you a schematic of this FDC ? Which part are used on this board ? (a board scan may be interresting).
coredump
Post by coredump »
Jeff wrote:4 ms ? ouch... i wonder what the controller expect with such small time. The write recovery time of some floppy disk drive are longer than this. For sure the sd / flash write completion can't be done into this period.
I think the DSD 4140 has something strange behaviour. Generally, FDD defines minimum recovery time (typically 590 - 690 us) but does't do maximum.
I have not yet found schematic of it. I have just user's manual. I downloaded it from the link in the following website:
http://www.filewatcher.com/m/040002-01_ ... 572-0.html
The user's manual shows the READY signal is not used but it is not true. The DSD 4140 requests the READY signal like typical 8-inch FDD. I think this FDC has many traps.
I'll prepare a picture of DSD 4140 on Monday.
I will get more signals. I have another Q-bus controller which works with HxC2001 (both read and write). Also, DSD 4140 works fine with real 8-inch and 3.5-inch FDDs (YD-174, YD-180, TEAC FD-235HG and MITSUMI D353M3D); I will check signals with real FDD.
coredump
coredump
Post by coredump »
Jeff wrote:Which part are used on this board ? (a board scan may be interresting).
I took pictures of the DSD4140 controller.
Parts side
https://www.dropbox.com/s/eqmrvyqrp3v6c ... e.jpg?dl=0
Solder side
https://www.dropbox.com/s/w9e9ifgpuj7z1 ... e.jpg?dl=0
This controller generates the STEP signal 700-770us after the rising edge of the WGATE signal. Does the HxC2001 accept that timing?
Step signal after rising edge of WGATE:
https://www.dropbox.com/s/1bf68vtleh55l ... e.jpg?dl=0
Yes it does (the track change is recorded). Did you have this step with the HxC ?
coredump
Post by coredump »
Jeff wrote:Yes it does (the track change is recorded).
Thanks, Jeff. I'll try to find other timings.
Jeff wrote:Did you have this step with the HxC ?
That was the signals with real 3.5-inch FDD.
Anyway, I have uploaded new images of signals with real 3.5-inch FDD and HxC2001.
The DSD 4140 controller becomes crazy after writing, generating strange step pulses, when it is connected to HxC2001. The DS becomes high after rising edge of the WGATE signal, then the controller generate strange step pulses.
I have not yet found why I cannot use HxC2001 with the DSD 4140. What kind of signals should I get?
coredump
Real 3.5-inch FDD
INI command of RT-11
https://www.dropbox.com/s/jq07z3ptm0jbx ... 2.jpg?dl=0
https://www.dropbox.com/s/79srhsti9cmws ... 3.jpg?dl=0
COPY command of RT-11
https://www.dropbox.com/s/qfpqtv0ynirdp ... 9.jpg?dl=0
HxC2001
https://www.dropbox.com/s/8fhryykrb0k7a ... 1.jpg?dl=0
https://www.dropbox.com/s/7tt2ksiwlzvvg ... 5.jpg?dl=0
https://www.dropbox.com/s/ymq7o2ch03401 ... 7.jpg?dl=0
https://www.dropbox.com/s/76w614wnnhoqx ... 8.jpg?dl=0
