Backup Arburg System Disks To SD Card
georrick
Post by georrick »
Hello All,
I'm trying to backup my Arburg system disks with a KryoFlux unit and then convert them to SD to use with the HxC Floppy Drive Emulator. I have been able to use the sample Arburg DATADISK_001.hfe in my converted machine and I can read and write to it fine. The problem comes when I try to convert my existing disks to hfe files. I believe it may a format issue that I may not fully understand. Can anyone provide me conversion steps or format info.
Thanks in advance,
George.
Re: Backup Arburg System Disks To SD Card
Send me an email :
i will provide you an ftp server to upload your raw files. I will check them.
