Ensoniq EPS 16+ - Disk images - Disk Label Write
polysix
Post by polysix »
Hello forumusers,
first i will tell you that i m verry happy with the Hcx rev F in my EPS16+. All works well and nice!
But i have some questions and i hope i find here a answer.
I use the EPS with memory upgrade. Is there a way to create a image for a size lager than a standard EPS floppy lmage? It was so great for me to have a image that do have the same memory as my ram.
Is it right that i cant save a Disk Label from the EPS side to a image? if the EPS ask for a other disk. Is there a way for it?
How do you EPS users organize your images that you know with sound is on it?
Thanks a lot!
polysix
polysix
Re: Ensoniq EPS 16+ - Disk images - Disk Label Write
Post by polysix »
Hi there,
are all the things i ask not working?
I will be verry happy for a short answer :)
Thanks a lot
polysix
polysix wrote:Hi there,
Thanks a lot
polysix
Sorry i don't know at all if the image size can be expanded on Ensoniq. Maybe some Ensoniq specialist have the answer, but i am not sure if they are on this forum.
I don't understand this question : The HxC act as a floppy drive, so what you can do with a floppy, you should be able to do the same with the HxC.
polysix
Post by polysix »
Hello Jeff,
thanks verry much for your support. All works well, and i can write the disk labels like a real floppy. Why this don´t work at the first images i make i can´t say. I use today the images from your headquater in the zip file and this are working perfect. Thanks ! I will buy in the next weaks a second HXC for my new ASR-10.
I hope there is a way to create a bigger image like the 1,5 floppy for our Synths and Sampler. My new ASR10 do have 16 mb Ram. And i thing there will be so nice, if i can save a complet RAM on one file. This was a dream for Organistaion the sounds :D
Jeff, i hope for the future as a big fan of your HXC Emulators, that this future do have a chance. I read in so many forums that this is a big wish for synth an dsampler fans !
Greats and thanks
polysix
The emulator support bigger images, but the depending of the file system used by the machine, this may work or not. FAT12/DOS disk based system often support this.
