C64 Support ?
Neil79
C64 Support ?
Post by Neil79 »
I've had the HxC SD for a month or so now for the Amstrad CPC 6128 and have recently come across a cheap C64, however the tape deck is a right *Censored*. It sometimes works and sometimes doesn't and unlike the Amstrad, wont play Tapdancer loaded tapes.
Will there ever be any support for the C64?
Re: C64 Support ?
Some hardware hacking are needed into an old 1541 drive to connect the HxC.
12bitski
Re: C64 Support ?
Post by 12bitski »
I know, I´m nearly 10 years late, but resently got a C64 and a 1541 with a lot of floppies for cheap. But I would like to connect the HXC to the 1541.. maybe with a switch to use both, the HXC and the physical drive ....like I did on the SP1200 ;D
Where can I find the hack for the 1541?
