Problem with ONE image disk
huggyone76
Post by huggyone76 »
I'm just trying to run the demo "Day Of Reckoning" on my A500 with my HxC.
I found some disk images of the demo, for example here :
http://cyberpingui.free.fr/dl.php?id=231
The disk image is perfectly read under WinUAE.
I tried to make a HFE file with HxC Floppy soft (load the image, export) and ADFOpus. I wrote the HFE file on my SD Card (even after a fresh format). My A500 boot and run the demo... But after a few seconds, the HxC "turns" around track 50 to 54 really slowly and nothing happen...
No problem with others demos, games, softwares... only this demo (I didn't try ALL the disks, but that's the first time I have this problem since months !).
Is someone can try on his own HxC please or help me to find a solution ?
I've got the last firmware (no beta version), the last software.
Thank you.
Re: Problem with ONE image disk
huggyone76 wrote:Hello,
Thank you.
try the beta firmware and try to use the "rev 2" hfe file format.
huggyone76
Thank you for your answer.
So, I tried with the beta firmware and the "rev 2" hfe file format.
That's "better" because the demo started and run for approximatively 90 seconds and... crash, always at the same moment (but that's better than the previous tests).
Other ideas ?
Thank you.
huggyone76 wrote:Thank you for your answer.
Other ideas ?
Thank you.
i must to try it to check.
huggyone76
Thank you Jeff !
The floppy disk seems very "special". When the A500 read this, the sound is... special ! Even with different floppies or floppy drives... And no problem with other floppies.
huggyone76 wrote:Thank you Jeff !
Tried here and no crash. (A500 / 1MB / Last beta version / Rev2 HFE)
What is your jumper setting ?
huggyone76
I'm in this configuration, Amiga, no twisted floppy cable :
I'm going to try with only Drive A.
Thank you.
huggyone76
OMG !!!! :oops:
I found... So sorry you lose time with that ! :( That's simply that my floppy cable IS twisted !!! So my jumpers were not at the right place ! :(
So... Good news... Day of Reckoning work PERFECTLY well on the HxC Floppy ! ;) What a shame... SORRY ! And thank you for your help.
Regards,
Hugues.
