Can't find disc on first run?
Neil79
Post by Neil79 »
Ok I load up the HxC manager, select R-type disc A in slot 0 , disc B in slot 1 then quit and save.
Running the command Run"disc and it says it can't find disc, typing in cat and it shows a dot and a 0 file size, same with the second disc.
If I press the switch on the HxC device to go through both discs and HxC then back to slot 0, the game shows up fine >:(
( This seems to be a problem with the two disk games especially homebrew and demo scene only )
Re: Can't find disc on first run?
Which switch have you set ?
Neil79
Post by Neil79 »
The recommended ones from cpcwiki
1 - ON
2 - ON
:shock:
Forgot to mention HxC SD Slim, thanks 8)
Can you share your SD content ? I will try this here.
Neil79
Post by Neil79 »
Jeff wrote:Can you share your SD content ? I will try this here.
It's over 4GB :lol:
But here's two disks from the R-Type 128k version that doesn't work for me after first HxC Floppy Emulator Manager save.
http://homebrew.amstradtoday.com/games/r-type_a.dsk
http://homebrew.amstradtoday.com/games/r-type_b.dsk
I have to go through the drive slots again and come back to the disk in slot 0 to get it to show up.
Games like Dizzy for example work straight away and can be played straight after quitting from the manager
It's over 4GB :lol:
Please share your cfg file and autoboot.hfe file too.
have you tried the old autoboot.hfe (v2.5) ?
Neil79
Post by Neil79 »
Here are my files
AUTOBOOT.rar
(28.89 KiB) Downloaded 3121 times
Neil79
Post by Neil79 »
After selecting this
and using SDCard_HxC_Floppy_Emulator_Manager V2.5 ( NOT 3.0 )
So far it's working!
It actually looks better and is easier to read the files in the manager as well :)
Cheers Jeff
