To reverse an image that has been converted to .HFE
Audronic
Post by Audronic »
Hi Jeff
I am wondering is there a program that can reverse an Image that has been Exported to xxxxxxx.HFE
In My case an xxxxxxx.JV3 that has been turned into a xxxxxxx_JV3.HFE.
Ray
If it ain't Broke then PLEASE DONT fix it.
Procrastinators Unite !
Re: To reverse an image that has been converted to .HFE
Audronic wrote:Hi Jeff
Ray
Just one question : JV3 is a TRS80 file image.
Are we talking about the same thing ?
If yes, you have just to change the target file format into the file selector
Audronic
Post by Audronic »
Hi Jeff
Yes its for a TRS-80
Thanks Ray
Thanks Ray
ok then load the hfe, export and change the target for jv3.
that's all.
you can all use the batch convert if needed.
Audronic
Post by Audronic »
Hi Jeff
Thank you , Yes it works.
The xxxxx.hfe to xxxxx.JV3 convert back works , Yeahhhh
A Brilliant piece of Software and Hardware.
Ray
