Prophet 2000 problem
HxC Floppy Emulator Sequential Prophet Keyboards support
Temple
Post by Temple »
I've had my HxC for quite some time now and have been using it with great success with my Ensoniq Mirage. I recently acquired a Prophet 2000 with no discs so I thought I'd give it a go with the HxC and try and build my own library sampling from my other synths. I have transferred the img files from here onto my SD card, but the prophet keeps coming up with nd (no disc). I'm pretty sure the prophet is ok because I can put a disc in it's old drive and it tries to load the blank disc and gives me the ns error.
I'm probably missing some thing really obvious but any help would be much appreciated.
Marc.
Re: Prophet 2000 problem
Have you set the interface mode to shugart ?
How did you generate the hfe file ?
Temple
Post by Temple »
Thanks Jeff I've sorted the problem now I had to swap the IDE cable round and cut the tab off I had the same problem with the mirage just needed some lateral thinking! Also if anyone would like to do any swaps I have a large Mirage img library practically all the factory discs plus loads more which I'd happily trade for Prophet img's.
Thanks Marc.
