Saving W30 songs to the HxC
Yinyue jia
Post by Yinyue jia »
Hi Jeff...The HxC is great :-) it loads easily to my Roland W30...however it won't let my W30 save files to it...WHY? ...message 'disk protected' appears. All my (280) w30.hfe files load but can't be re-saved...any help please?
Re: Saving W30 songs to the HxC
Yinyue jia wrote:Hi Jeff...The HxC is great :-) it loads easily to my Roland W30...however it won't let my W30 save files to it...WHY? ...message 'disk protected' appears. All my (280) w30.hfe files load but can't be re-saved...any help please?
Try to disable the write protect switch usage into the embedded menu (press select without sdcard).
Yinyue jia
Many thanks Jeff :-) didn't know I had that! Unfortunately, now for some reason it won't load any disks. I'll start all over again and refresh all the HxC settings and let you know what happens. Maybe I touched something else on the way. Thanks for your help, I'll reply soon.
Yinyue jia
Absolutely perfect! No problem now, thank you Jeff. Out of curiosity there are files showing up recycled Di480/488.hfe...these are just deleted files? Have a good week :-)
