Hxc SDF Floppy Drive Emulator in Yamaha EL-70 organ?
homerian
Post by homerian »
Hello guys,
I am looking at purchasing an HxC SDF Floppy Drive Emulator to replace the floppy drive which forms part of the MDR (Music Disk Recorder) in my Yamaha Electone EL-70 organ.
As the floppy drive is a NON-standard floppy drive instead of a PC drive, will the HxC still work?
Does anyone have any experience of using the HxC in a Yamaha MDR?
Re: Hxc SDF Floppy Drive Emulator in Yamaha EL-70 organ?
homerian wrote:Hello guys,
Yes this should work !
Paradoxic
Post by Paradoxic »
I have an EL90, which uses the same MDR (Music Disk Recorder) as the EL70.
From my investigations, the differences in this Organ from a standard PC type floppy drive are....
* Pin 2 is a signal from the disk drive to the organ controller signifying an HD disk. ON = Ov = HD 1.44MB, OFF = DD 720KB
* Pin 34 is Drive Ready, 0v when ready, rather than Disk Change
* Motor on signal is permanently ON, so a mechanical drive is permanently spinning when a disk is inserted.
* The in use LED illuminates only when data is being transferred, rather than when the drive is spinning.
I was wondering if the emulator can be fully compatible.
rgds
Ian
Paradoxic wrote: I was wondering if the emulator can be fully compatible.
rgds
Ian
yes! :)
Paradoxic
Post by Paradoxic »
rgds
Ian
yes! :)
Can the Gotek hardware (which I have) also be made compatible?
I have it still on the bench, not yet in the organ.....
With v3.0.6.0a firmware and the "Normal_Mode"configuration file I seem to have continuous 5v ( ie OFF) signal at pin 34 where I was expecting it to switch to 0v when an image is loaded.
rgds
Ian
yes! :)
probably
Paradoxic wrote: I have it still on the bench, not yet in the organ.....
True only if the drive is selected by the machine...
Paradoxic
Post by Paradoxic »
Paradox wrote: I have it still on the bench, not yet in the organ.....
Thank You.
I have been working on physically mounting the LCD. I can now proceed to connect to the organ. :)
Paradoxic
Post by Paradoxic »
Finally........
Got around to fitting Gotek emulator with i2c LCD, running software version v3.0.6.6a, into my Yamaha Electone EL90 organ
and........
After initial testing I can confirm satisfactory record and playback.
It's so good to be able to navigate a directory structure with meaningful folder and floppy names rather than anonymous 000-999 floppy numbers! A great result !!
It is my understanding that EL70 and EL90 use the same disk drive
EL500/EL700 should also work with slightly different configuration. They utilize a disk change rather than drive ready signal at pin 34, which is configurable.
One question I have though, is ....
Are there any plans to include all configurable items into the UI of the floppyemulator software? It seems the number of configurable items has outpaced the software.
Ian
Ian
If you are talking about the pins settings, this is available into the beta software :
Paradoxic
Post by Paradoxic »
Yes, about the function of pins 2 and 34.
Thanks. I hadn't spotted that update. I'll take a look.
kpw
Post by kpw »
Jeff wrote: Fri Apr 10, 2015 8:37 am
rgds
Ian
yes! :)
The MDR does not work for me on the EL-70, either no HxC Rev F, nor a fresh burned GOTEK.
Does Jeffs “yes!” mean that the HxC Rev F should work only with the reverse connected cable, without any further modifications? :?:
I always get the error message "inSt" (no disk inserted) when I press some button. The DiskBrowser shows all disks fine. HxC and GOTEK on a PC as floppy even works fine.
Thanks for any help!
kpw
Post by kpw »
Many thanks to Jeff for his superior support, he saved my day!!
For anyone who has the same problem:
HxC Floppy Emulator settings, 3,5'' 720KB DSDD FAT12.png (38.91 KiB) Viewed 89531 times
-> Switch to ID0A / S0 to ON
Best regards, Steffen
