Sorry for possible English mistakes, I'm spaniard.
I just purchased a SD HxC Floppy Drive Emulator Rev.F for an A2000 with an internal and original "df0:" floppy drive. So, I'm only interested in "df1:" emulation in order to transfer files from my PC to the Amiga.
I have the following issue:
When I insert the SD card, the left red light is continuosly flashing and de LCD display shows a permanent "Reading FAT..." status. Nothing else happens.
I'm using a 64MB microSD card (with the adaptor), but my Windows 7 only lets me format it in FAT (no idea if its FAT16 or FAT32). I don't know if this is a possible cause.
I figure the jumpers are correctly set, (jumper #2 ON only=one drive, df1). The ribbon cable is Shugart, with no twist in the conector to HxC, and then with the twisted conector in the original df0 device.
Kind Regards!
Edit: A question. What is the ID3 jumper "Motor Control Line" purpose or utility?
Permanent "Reading FAT..." status
Re: Permanent "Reading FAT..." status
Yes this is a sd problem. can you try another one?Bothman wrote: I'm using a 64MB microSD card (with the adaptor), but my Windows 7 only lets me format it in FAT (no idea if its FAT16 or FAT32). I don't know if this is a possible cause.
Bothman wrote: Edit: A question. What is the ID3 jumper "Motor Control Line" purpose or utility?
twisted floppy cable usage, Pc usage...
It is will be FAT16, the Windows don't format FAT32 under 512MB size.Bothman wrote: I'm using a 64MB microSD card (with the adaptor), but my Windows 7 only lets me format it in FAT (no idea if its FAT16 or FAT32).
Previously I wrote a trick with FreeDOS can be possible formating small cards to FAT32:
https://hxc2001.com/floppy/forum/viewtopic.php?f=2&t=1260
Yes. That was the problem. It's working fine with a new 2GB SD Card.
Thanks, Jeff and Zozosoft, for your answers.
Kind regards!
Kind regards!
