Once again - installation problems - PLEASE HELP ME!
Elmbeatz
Post by Elmbeatz »
Hi guys!
I have this Emax (1) Rack unit, in which I installed a Rev F (Rev-C-based) Floppy Emulator. Hardware-wise, I'm sure that I installed the unit correctly.
But - I can't get the setup to work correctly. Here's what happens:
- The Emax starts loading a disk(image) when selected on the HxC.
- Then the Emax stops loading and seems to freeze.
- I used several different Emax-OS (*.emx files - all renamed to emaxos.emx each time) in the same folder as the *.em1 files before converting these to *.hfe files.
- I also used the files from the "Quick Install Zip" that is provided here
- Depending on the Emax-OS I used (in the conversion folder), the "freezing" looks different. Sometimes loading stops very quickly, sometimes the display turns blank, sometimes the loading process seems to start over and over again, sometimes gibberish or black display - different weird things.
To exclude the possibility of the Emax itself being faulty, I tried the HxC Emulator in my second Emax (Keyboard), and the same things happen (this one still has a functioning floppy drive that loads my old disks). I also swapped the Scanner MPU of both units - no success.
CAN ANYONE HELP ME OUT OF THIS DILEMMA? Could anyone give me a step-by-step-guide or maybe piont me where I'm doing something wrong?
P.S.: I remember that I upgraded the Rack emax to SE at some point in the past (via floppy disk) - maybe this has something to do with things going wrong? (As I said - I tried all kinds of Emax-OS for Hfe-conversion - the SE-OS, too, of course...)
Thanks a lot in advance for helping me!
Elm.
Re: Once again - installation problems - PLEASE HELP ME!
Have you a way to make the HFE images from your floppy disks ?
ethergreta
Post by ethergreta »
Having same issues here too on emax model 1010
Help! :x
ethergreta wrote:Having same issues here too on emax model 1010
Help! :x
https://hxc2001.com/floppy/forum/viewtopi ... axos#p6943
