Sinclair QL
XorA
Sinclair QL
Post by XorA »
Hi, I have written a loader for the Sinclair QL .img files produced by Q-Emulator and the qltools packages.
I have tested the resultant DD and HD hfe files both read and write on my actual QL and they
seem to be functional.
This was from information in the other QL thread here with RWAP!
ql_loader.tgz
(2.33 KiB) Downloaded 918 times
Re: Sinclair QL
Thanks will integrate this ! The format look likes very similar to the PC. i am missing something ?
XorA
Re: Sinclair QL
Post by XorA »
I don't know much about how floppy disks work, but I get the impression the physical format on disk is the same as a PC. Just the filesystem is different.
It may be you can improve on some of the magic numbers that I did not really understand.
Re: Sinclair QL
XorA wrote:I don't know much about how floppy disks work, but I get the impression the physical format on disk is the same as a PC. Just the filesystem is different.
almost the same : the first sector id on ql is 0.
XorA
Re: Sinclair QL
Post by XorA »
I have learned some things doing the qltools integration, I shall update this loader when I have a chance!
XorA
Re: Sinclair QL
Post by XorA »
And the promised upgrade, this one uses the disk header info to detect the size of the disk rather than guessing from file size.
I also implemented writing as this works well with the qltools mod.
libhxcfe API is awesome :-)
Graeme
ql_loader.zip
(4.18 KiB) Downloaded 987 times
