HxC Rev.B and Floppy Manager V3
tophe38
Post by tophe38 »
Hi everybody,
I'm a happy owner of severals HxC and a cpc 6128+.
Using the same 8 Go SD card, HxC floppy manager V3 work great on HxC Rev C., but hang at "Reading config file" on HxC Rev B.
Is Floppy Manager V3 is able to work on HxC Rev B. ?
Else, in "normal" mode (using HxC LCD and on board button), HxC rev B. works great, only floppy Manager v3 don't seem to work.
On HxC LCD Rev B, I can read
Direct Access
LBA:00000000WESE
SD Card Access LED is blinking very fast.
If I reset the CPC, I can see it "rewind" from track 240.
Both HxC (Rev B & C) are using firmware 1.8.2.40.
Any idea ? (maybe I should try another SD card....)
Edit : I try an older version, 2.5, same result :
Keep reading configuration, "Read" blinking on top right of the screen.
Regards,
Christophe
Re: HxC Rev.B and Floppy Manager V3
You need the version 1.7.2.0 for the rev B
tophe38
Post by tophe38 »
Thanks for answer.
I see deep in the changelog, that 1.7.2 is the last version for Rev B.
I give a look at your download page, and I did not see any link for previous firmware download.
Could you provide me a link please ?
Regards,
Christophe
rickyordi
Post by rickyordi »
tophe38
Post by tophe38 »
Thanks for provide a previous firmware link.
Unfortunatly, it doesn't solve the issue.
The same HxC (Rev.B) work perfectly with Amiga version of Floppy Emulator Manager.
Regards,
Christophe
