Slim LED
Arnie
Slim LED
Post by Arnie »
Is it possible to disable the 'Card Inserted' and keep the 'floppy access activity' of the LED?
Or do I need to cut the traces to the LED and take a wire from the floppy connector directly to the LED?
Kokos
Re: Slim LED
Post by Kokos »
Hi Arnie, any progress on this item?
Arnie
Re: Slim LED
Post by Arnie »
No none I'm afraid. I now own a rev F so the Slim is in the drawer.
Re: Slim LED
For which purpose do you want to change this ?
BTW the solution is quite easy : just reduce the standby time to its minimum into the cfg file.
