AUTOBOOT problems
TroelsDK
AUTOBOOT problems
Post by TroelsDK »
Dear support.
I' having problems with the AUTOBOOT / File Selector.. :(
My HxC works just fine with normal use; Selecting the files from the HxC display, but auto-boot function freezes in start-up.
It boots up and goes to the "welcome" menu, but then a long beep is heard and the message "DIRECT ACCESS LBA:00000000 08" is displayed.
Then the menu is frozen...
I have read the manual several times, and updated the firmware to newest version, HXCFE_V1_8_2_40, using a freshly formatted FAT32 SD-card.
I've tried formating the SD-card again with brand new downloaded AUTOBOOT.HFE and brand new HXCSDFE.CFG setup to auto-boot from default.
I've tried running the card with the prepared files from the download site, containing the Arte demo.
The HxC itself has the buttons extended, not the original ones, but from the place that is given to do so.
The display is also extended. But unplugged or not, still the same problem.
Please help me!
How do I correct this?
Troels
Pics: http://postimg.org/gallery/3cm6g9cqg/
Re: AUTOBOOT problems
mhh quite strange. Have you tried to change the floppy cable , the switch setting.
Is the amiga ok ? have you tried to refit the amiga chipsets ?
TroelsDK
Post by TroelsDK »
Jeff wrote:mhh quite strange. Have you tried to change the floppy cable , the switch setting.
Hi Jeff.
Yes I'm sure the Amiga is completely in working order, but to be sure I have tested in two other A500's.
The HxC has no problems playing the adf's without autoboot..
I'm using a Transcend 8GB SD-card, maybe some compatibility issues there?
Tried with a Kingston 4GB to make sure... didn't help
All the connections from the mods have been tested with a multimeter, no problems there either.
All the custom-chips/CPU/ROM checked, didn't help.
Tried again with no button/display extensions, didn't help.
I just noticed another thread a few years back, mentioning the same problem...
viewtopic.php?f=5&t=759
...but doesn't give any solution other than suggestion hardware failure... (?)
Video of the problem here:
http://www.youtube.com/watch?v=_8dyiqwP ... e=youtu.be
Most of time this was a problem with the Amiga itself...
Are you able to write something (a file) on a amigados image ?
TroelsDK
Post by TroelsDK »
Jeff wrote:Most of time this was a problem with the Amiga itself...
Yes I have a 1200 too :)
TroelsDK
Post by TroelsDK »
I assumed you had some test file I should copy to disk and use somehow..
TroelsDK wrote:I assumed you had some test file I should copy to disk and use somehow..
just start the WB then select the AUTOBOOT.HFE, and create a folder on it for example.
Then eject & reinsert the image or the sd : the folder should still there...
Once done please send me back the AUTOBOOT.HFE file.
TroelsDK
Post by TroelsDK »
I'm sorry I can't figure out what you mean... Open Workbench on HxC?
TroelsDK wrote:I'm sorry I can't figure out what you mean... Open Workbench on HxC?
Please start the workbench on your amiga.
TroelsDK
Post by TroelsDK »
Okay, used internal DF to boot Workbench, then inserted AUTOBOOT.HFE via HXC as external drive.
- Copied the folder 'Empty' to it.
- Ejected AUTOBOOT.HFE, inserted AUTOBOOT.HFE ; Folder 'Empty' is still there.
Here is the altered AUTOBOOT.HFE
http://speedy.sh/pg8gX/AUTOBOOT.HFE
I hope this is what you meant?
TroelsDK wrote:Okay, used internal DF to boot Workbench, then inserted AUTOBOOT.HFE via HXC as external drive.
Yes exactly ! This means that you can read/write to the emulator !
Anyway please send me the HFE file by email... speedy.sh ask to run an exe file : no way ;)
Still an signal to check : the index. I will send you a new autoboot.hfe to test this one.
TroelsDK
Post by TroelsDK »
That's starange, it don't ask me to download any exe file.. Anyway, sent it to your email now :wink:
telengard
Post by telengard »
I seem to be having this same issue. I've been using the HxC very successfully on my ST, but I cannot launch images from the floppy manager on my Amiga 500, just from the front panel.
Should I re-format and lay everything down again?
To all people having this issue : Can you tell with A500 motherboard revision you have?
