Slim SD HxC Floppy Emulator: Usage of ADF and other formats?
Spede
Post by Spede »
Does HxC floppy emulator slim version support other file formats directly than HFE? Manual mentions that "The Slim SD HxC Floppy Emulator use the HFE file images format.".
Tried to boot ADF images but no go but after conversion to HFE format it worked flawlessly.
Slim SD HxC Floppy Emulator User Manual
Rev.1.3 – 26 August 2013 - Page 9:
btw. HxCFloppyEmulator v2.0.20.1 may contain bug. If user selects "Batch converter" and converts for example ADF-images from "Folder1" to "Folder1" it goes some sort of loop forever (it converts images again and again :) ).
Re: Slim SD HxC Floppy Emulator: Usage of ADF and other form
Spede wrote:Does HxC floppy emulator slim version support other file formats directly than HFE? Manual mentions that "The Slim SD HxC Floppy Emulator use the HFE file images format.".
This is exactly as say the user manual : "The Slim SD HxC Floppy Emulator use the HFE file images format.".
This is not a bug : since HFE files can be converted too to another format, the converter take all files, including the newly created.
You must choose another folder as destination.
