HxC Rev C with ACA500
MaTel
Post by MaTel »
I have some trouble with a ACA500 and a HxC Rev. C. In the early bootmenu of the ACA500 you can create a Recovery-Disk. But this function breaks with a validating error after some tracks. The interruption differs from times to times.
Re: HxC Rev C with ACA500
MaTel wrote:I have some trouble with a ACA500 and a HxC Rev. C. In the early bootmenu of the ACA500 you can create a Recovery-Disk. But this function breaks with a validating error after some tracks.
Please send me the HFE file after the failure.
Which firmware version have you ?
MaTel wrote: The interruption differs from times to times.
How ?
MaTel
Post by MaTel »
Ok, tomorrow you get a .hfe file.
1.8.2.40 and 1.8.6.10a ( alpha? )
(on a HxC RevC and a cased HxC Rev C. with different floppy-cables, different SD-cards, different Amiga power suplies )
How ?
sometimes it goes from Track47 to Track36, sometimes it goes from Track47 to Track25 but it never comes accurate to the end of the process.
MaTel
Post by MaTel »
Here is a test.hfe.
I have created it with ADF-Opus and formatted with WB3.1. After that I boot into the ACA-Bootmenu an create a Recovery-disk. After round about 5 Tracks it breaks with a validating-error.
TEST.7z
(87.12 KiB) Downloaded 702 times
MaTel wrote:Here is a test.hfe.
I need the file without the WB3.1 format...
MaTel
Post by MaTel »
next try...
here is a unformatted TEST2.hfe created with ADF-Opus. ACA500 Recovery came from Track 47 to Track 42? an breaks then with an validating error.
TEST2.7z
(69.58 KiB) Downloaded 705 times
MaTel wrote:next try...
The image looks ok. Have you tried to disable the acceleration before making the recovery disk ?
