Questions about installation.
kal El 9311
Post by kal El 9311 »
Let me start by saying I love your product. I have successfully installed a HxC in my SP1200 and it is working perfectly. I also have an Emax I would like to do the same with. My question is: What are the jumper settings? Are they the same as the SP1200? There was a video guide on YouTube for the SP1200 installation. Is there one for the Emax? Thank you in advance.
kal El 9311
Re: Questions about installation.
I installed emulator. I unzipped emax Quick install directly on to SDCard. HxC reads card info, but Emax says "insert diskette". I do not own a computer with ad n internal floppy and cannot convert os disk. I feel I am not far off. Just need a little guidance.
reconnect the floppy cable to the other way (colored wire to the other side...)
kal El 9311
Flipped cable. It now just says loading software and the preset definition and analog processing lights are lit. Once again, I just unzipped the quick install directly onto the SDCard. I will try a different brand of SDCard. The one that works with my SP1200 is not the same brand. If that doesn't work I will repost. Thanks again for your help.
kal El 9311
Different SDCard did not work. Same results. Any Suggestions?
Sorry No idea at all. I have no enough elements here.
You don't even told me which emulator you are using...
How i can help you without any pictures or any details ? :cry:
kal El 9311
Sorry. I ordered two rev f's.
kal El 9311
Jeff. I apologize. I flipped the cable again and everything loaded as promised. I must not have seated it properly the first time. I also reformatted the SDCard (the first time I just did a quick format). All is good. Thank you for attempting to help me.
